2007 chrysler pacifica. 3.8l, stuck in third gear.
So everyone. Weird issue going on... about 2 months ago, my Pacifica refuses to shift out of 3rd gear. Registers park, reverse, neutral, drive, and auto stick. But I cant get it shift into any gears other than 3rd. Reverse works great, but even auto stick forces me to stay in 3rd gear. I need help. I've cleaned all connectors plugged into the transmission. I've checked fuses and relays. I get a P0882- low tcm voltage code and some other stuff like an o2 sensor code and a multiple misfire code. But I'm focusing in the transmission right now. Anyone else experienced this? I believe it's a 62te transmission, but everywhere I read says my 3.8 only came with the 42te so I'm not even sure on the transmission anymore. I just need some help. Thank you in advance
How old is the battery and what condition is it in? Low voltage due to a weak/failing battery can cause all sorts of sorts of weird and seemingly unrelated issues and obd codes (trans, O2, misfires). You may also want to check to check out the alternator; a failing diode can allow an ac ripple through that can mimic a low voltage condition or possibly reset some of the computer modules/components.
Brand new battery actually. I put a 65 series battery in since it fits and I have a ton of them thanks to all my fords. Alternator puts out average of 14 volts, my live alternator tester shows I stay between 13.8 volts to 14.2 volts when under a load.
If you or any of the other readers can shed any light, it would be greatly appreceiated.
I am curious to know if you have been able to correct this problem. I also have a 2007 Pacifica that is stuck in 3rd gear. New battery, trans fluid level correct, no scent of burnt trans fluid, fluid is clear on dipstick. Park, neutral, reverse all work fine. Auto-stick always shows 3rd gear and won't change. I am unable to read any codes due to a damaged OBD data port. I really hate the thought of randomly replacing parts to try to fix the issue.
The problem started with the car periodically shifting out of 3rd much slower than other gears. It would do this maybe once or twice a week. more often if it was raining. Finally, after about one month, it just decided it liked 3rd gear and wouldn't shift into any other forward gear.
If you or some other member may be able to shed some light on this, it would be greatly appreciated.
Thanks in advance,
MisterDK
Thanks in advance,
MisterDK
Thanks in advance,
MisterDK
Thanks in advance,
MisterDK
I did find a company that will take your existing PCM, repair it and re-flash it with the most current software version for a little over $100. Tempted to give them a try. I was talking to another person that was a mechanic. He suggested a couple of things also. pull the PCM and make sure all the contacts are clean and corrosion free. also disconnect the battery and leave the ignition switch in the on position to drain any residual power left in the electronics. I may try those before going the repair route.
I had a bad experience with the PCM on a Chrysler 200 a few years ago. the shop had to replace it because it was totally fried. The case was actually melted in a couple of spots. The New one was supposed to be programmed for the car when it was delivered to the shop. When it arrived and was installed the car woild not start, For some reason the vin that they programmed it with (which was the vin from the car) wouldn't work with the car. ended up having to put the old one back in, take it to the Chrysler dealership and they had to re-flash it. Not once, but twice. the flash didn't want to take. It only lasted a couple of months and did the same thing again. ended up trading the car in after that.
Thanks in advance,
MisterDK
Thanks in advance,
MisterDK
https://www.factorychryslerparts.com...5140429AA.html
I hope this helps.
Voyager_2000
22
Aug 28, 2015 06:07 PM
