Dash lights stay on with car off
Old Feb 17, 2020 | 10:09 AM
Hi_Bill's Avatar
PS. It's in the back seat, not the front seat. I would never have found this if it were not for this thread. Thanks Rbailey19, give yourself a prize!
Old Feb 17, 2020 | 10:11 AM
Hi_Bill's Avatar
PPS, the molding directly under the door will pop out if you put a screwdriver under it and pry it up. Do one end at a time.
Old Dec 9, 2020 | 04:45 PM
Dee Scott's Avatar
Default What color was the wire that was broken?
Originally Posted by FRANKY
Just finished solving this issue.
front control module by the battery at the blue connector found a broken wire that feed the bcm with power circuit to put the instrument
cluster to sleep.......................... good luck guys.
I’m trying to find the wire you are talking about. What color is it?
Old May 14, 2022 | 06:28 PM
Rmoniz216's Avatar
Default Before u changed wire out
Originally Posted by Rbailey19
So I would love to save everyone tons of money, I have a 2004 chrysler pacifica and when I turn the car off and remove the key the cluster lights stayed on and drained my battery. Well I tried changing the cluster and nothing, I changed the bcm and nothing well after a little research I discovered this is a very common problem and as I seen on this forum people are spending tons of money trying to figure out the issue, so here's what you do, you pull out the driver side rear floor panel pull the carpet back until you see the wires search for the grey and red wire 99.9% that wire is corroded and broke. There is one on one side and four on the the other you just cut off the corrosion and reconnect and walla everything works again!! "I would post pics but this site has no way of doing that"
So I did what u said and found the grey and red wire but on drive side it looks good but on passenger side it's all rusted and wet but wire looks intact was the wire u switched out was it obvious to the eye
ikappa
May 23, 2022 04:44 PM
TLKidd
Apr 15, 2015 06:49 PM
Bubble_City
May 4, 2009 06:23 PM
GSKI
13
Sep 11, 2007 09:33 AM
mongoose53207
Mar 7, 2007 11:55 PM
