oil pressure light
Old Jan 7, 2009 | 06:15 PM
paccar1's Avatar
Default oil pressure light
Has any one had this happen yet engine light came on so when I got to the store and checked the oil it was 1 qt low ,I put more oil in it and the oil light still comes on. The manual says it's the oil pressure light and to stop driving, any input would be helpful.
Old Jan 7, 2009 | 07:04 PM
scottydl's Avatar
Default RE: oil pressure light
You need to have a gauge put on it to read the oil pressure. If you drive the car with too low or too high oil pressure (which is caused by a bigger problem), serious engine damage could result. That quart low of oil went somewhere... when was the last time it was full?
Old Jan 7, 2009 | 08:37 PM
paccar1's Avatar
At the last oil change, I am 900 miles away from being due for another one. The vehicle just went on a trip to Tennessee would that use that much oil.
Old Jan 8, 2009 | 07:49 AM
scottydl's Avatar
Well in theory oil should NEVER be "used", but every engine burns or leaks a little eventually throughout its life. I don't what "a trip to Tennessee" means because I have no idea how many miles that is for you. But highway miles are the easiest on cars & components, so assuming it was a long highway trip then no that should not cause excessive oil loss. Being a quart low is not the end of the world or not all that uncommon in older & high mileage engines, but it could indicate a leak or other condition that is affecting your oil pressure. Hence the warning light.
Old Jan 8, 2009 | 05:00 PM
paccar1's Avatar
I will be taking it in on Monday for service, vehicle runs good maybe sensor went bad or when it runs low the sensor has to be reset don't know. I don't want my engine to blow by just brushing it off as "It's just a dummy light" It could be nothing serious and have to pay for something that I did not need to, or It could be serious and the warranty will cover it.She has 48,000 miles on her
with a strong 3.5 motor perhaps I'm just paranoid.On the last oil change I went to Walmart ,they refused to do it because the plug acted like it was stripped so I took It back to the dealer and they changed the oil, they did not mention that they had trouble with the plug. The oil has always been changed at the dealer and I have all the receipts since purchased. I do not see any oil in the driveway so maybe It leaks only when driving.Thanks for your input.
Old Jan 8, 2009 | 05:20 PM
scottydl's Avatar
That's pretty low mileage to be losing that much oil IMO. If it's still under warranty I'd certainly mention that and the oil plug. The oil plug should be mentioned anyway if they have been the only ones to change the oil then they stripped it. You could very well be losing oil out that way if it's cross-threaded. Post back with the results!
Old Jan 8, 2009 | 07:19 PM
paccar1's Avatar
I will have to drop It off late in the afternoon so I will post back on Tuesday.
Old Jan 13, 2009 | 08:02 PM
paccar1's Avatar
not sure where the quart of oil went and the dealership here in Rockford IL, are not smart enough to figure it out.The reason for the light coming on was an internal short in the oil sending unit
which cost $81.60 to fix, not sure if cold starts would affect oil usage or not as this is the first time that I have seen it use oil.Thanks for all the input
billbon8
23
Jul 18, 2011 04:48 PM
karotto
Feb 12, 2009 06:32 PM
deedee
Jan 16, 2009 10:48 AM
gbwiii
Jan 6, 2009 03:48 AM
ijiuini
Dec 5, 2008 03:18 AM
