PLEASE HELP!!! Drivers side lights not working
Old Sep 15, 2021 | 01:44 PM
Get a volt meter and see if you have power and ground at the bulb connection .
Old Jun 2, 2022 | 08:32 AM
06' Pacifica Owner's Avatar
Default Signal and driving, high beam out now
Did you figure this issue out? I had no signal lights in front. Now I have only 1 high beam(passenger) and one daytime(passenger)and one fog(drivers) all rear lights working fine.
Old Jun 2, 2022 | 01:30 PM
Old Jun 2, 2022 | 02:37 PM
All connections have been tested by Chrysler dealership and by a friend as well. Have proper voltage everywhere.
Old Jun 2, 2022 | 08:14 PM
  #15
brian3's Avatar
The grounds to the frame below the battery are notorious for breaking and causing front bulb issues. I had to repair mine in my 2005. Parking, turn signal, front side indicator, fog lamp, head lamp have all gone out at times due to grounding.
Old Jun 23, 2022 | 04:18 PM
  #16
jesoma's Avatar
I agree with Brian3. Happened to me. This ground has multiple wires and gets corroded. I first created my own headlight ground by splitting light ground and attaching to body. Eventually the main ground got so bad weird things started to happen, no ac, radio, dashboard, etc. Finally bit the bullet and fixed the main ground. Tight squeeze, pain in the neck to get to but can be done.
roger03105
Dec 22, 2014 02:33 PM
murphypat16
Oct 4, 2013 08:39 AM
mjwilky
Sep 15, 2010 12:01 AM
Johnbush1
Feb 22, 2008 04:00 AM
