Power Seat Recline Motor
Old Jan 27, 2011 | 08:53 PM
jasonolson's Avatar
Default Power Seat Recline Motor
I'm looking to see if anyone has ever replaced the power seat recline motor. Mine has gone and need to replace it and I can't find any info on replacing it or the part number for it.
Please help with any help you can give as far as trying to get the seat to return to normal angle (currently able to drive but laid back!) and replace of the motor and where to find it inexpensively.
Thank you!
Jason
Old Jan 27, 2011 | 09:23 PM
Djinn-n-Tonic's Avatar
The Motors are not available seperately, The seat Track must be replaced.
Now, having said that, look under the seat for a section of steel cable that has popped off the track......Very rarely they may be reatattched, but its worth a shot.
Old Jan 27, 2011 | 11:11 PM
jasonolson's Avatar
Default Confused
I'm sorry Djinn-n-Tonic, but i don't understand...So the seat track kit includes the motor? I don't understand how replacing the seat track would resolve the issue of the motor no longer being able to retract the seat from a flat/laying position up to normal.
Old Jan 28, 2011 | 10:28 AM
busboy4's Avatar
I am not inclined to argue with an active Chrysler mechanic. With that said however, my '05 factory manual indicates that power recline function is a product of a "powered hinge" if you will. In other words, the inboard hinge has a built in tilt motor function. Looking at my '05 limited I can see the geared hinge and motor drive shaft on the inside corner of both seats. The directions indicate you remove the seat back trim and pull up the cover to expose the hinge/motor. It indicates it is not a serviceable part and must be replaced as a unit (hinge/motor) if faulty. I don't find the part listed separately on chryslerpartsdirect.com so you might want to stop by a dealer parts counter. I have found my local folks to be very helpful and willing to print out a parts diagram etc.
Good luck with it. Sounds annoying.
carl
Sep 23, 2015 04:30 PM
DavidH7911
Aug 7, 2013 02:59 AM
Giroux28
Mar 22, 2011 05:36 PM
2006 pacifica
Oct 16, 2009 12:59 AM
jarek
Jun 1, 2009 02:07 PM
