No spark
Old Jan 31, 2021 | 07:56 PM
Redrigh's Avatar
Default No spark
Car ran fine blown head gasket. Replaced with rebuild head went to start no spark.check timing all good. Chated with online Chrysler mechanic he sent me diagrams to check wireing. Have power to coil no ground signals. He tells me must be pcm. I order new one same. Since I have checked crank sensor cam sensor both sending signal. Still no ground signal to coil. Getting flustered
Old Feb 1, 2021 | 06:06 PM
"Replaced with rebuild head" so do you have a scanner? can you see if the PCM sees the cam sensor signal? With rebuild heads the cam magnet on the driver side can be for a few different setups. so Id swap over the one form your old head to the new one.
Old Feb 4, 2021 | 12:29 PM
Redrigh's Avatar
if I unplug cam sensor it will throw cam sensor code. I assume that it is picking up. Let me know if I am wrong
Old Feb 4, 2021 | 12:31 PM
Redrigh's Avatar
returned magnet with core.
Old Feb 19, 2021 | 08:50 PM
Redrigh's Avatar
got new magnet today. I have spark today. Thanks so much for the help
Old Feb 20, 2021 | 09:02 PM
welcome seen it a few times
4UHoney
Apr 22, 2021 01:32 AM
TLT
May 23, 2017 03:13 AM
BigBlocksnHardrock
31
May 23, 2008 11:43 PM
jameslee522
Dec 15, 2007 09:55 AM
sosomech
Feb 7, 2007 03:18 PM
