07 Town & Country foglight wiring??
Old Aug 26, 2008 | 05:28 PM
vwomein's Avatar
Default 07 Town & Country foglight wiring??
Hi. I just got an 07 T&C. It didn't come from the factory with fogs, but I bought it used with
the dealer fog kit. It has the fog light switch installed into a hole that was drilled in the dash.
I want to get an OEM headlight/fog switch, and the wire harness from the frame rail to the lights(if that's available). I did this same thing in my 05 Ram truck. I want to make it like it came with fogs. I like that the look & use of the "real" switch, plus, the orig switch allows you to use the fog lights with the marker lights. Does such a harness exist for the van?(like in my Ram truck). I do understand, I'll need to add a fuse & relay for the fogs.
Help! and Thanks!
Brian
Old Aug 27, 2008 | 06:49 AM
vwomein's Avatar
Default RE: 07 Town & Country foglight wiring??
help me, Chrysler Tech,.......you're my only hope.
p.s. That comedy skit in your name is funny stuff "I kill you!!!"
Old Aug 28, 2008 | 12:34 AM
what u want to do will not work to the best of my knowledge.
The headlight switch is a Resistance mufti plex system and has to pass through a computer then sent over the network to the other computer controlling the fog and head lights.
The skit is from Jeff Dunham u might have seen him the comedian/ventriloquist that has been around for a long time.
Old Aug 28, 2008 | 08:23 PM
vwomein's Avatar
thanks for the reply. I was hoping to make the whole fog setup "O.E.M."
I'll keep looking, but for now, they do the job.
Old Sep 3, 2008 | 05:35 PM
vwomein's Avatar
ok then, ..........I see quite a few of you looked here, but didn't respond. For those interested, I got the final answer. If you want the fogs to work like orig equipment, you'll need to buy the headlight/fog harness. List is about $350, plus the headlight/fog switch. Also add a fuse & relay to the underhood fuse box. SO........forget it. They work fine like this. I just wanted the original look, plus the ability to use marker & fogs without the headlights on. I'll get over it.
Old Sep 13, 2008 | 12:04 PM
vwomein's Avatar
ONE FINAL REPLY HERE........I ended up taking the fog light power wire off of the low beam headlight, and
attatching it to the marker light wire. Now I can use fogs with marker lights(withor without the headlights on).
I can also use the highbeams with fogs on those dark roads when there is no oncoming traffic.
Old Sep 13, 2008 | 12:22 PM
last replay as well the way it was wired up was due to Law
it is agenst the law to have fog lights and high beam lights on at the same time hense why it was wired as such.
jeff618
Aug 15, 2011 11:47 AM
jpacific
Jul 10, 2009 11:43 PM
BIGMAN55
Feb 13, 2009 08:00 PM
neuroticdave
9
Nov 14, 2007 02:49 PM
Racinfan83
Jan 21, 2006 03:11 PM
