2.8 crd miss fire
Old Jan 30, 2013 | 06:54 AM
nicksmith's Avatar
Default 2.8 crd miss fire
have a 2.8 voyager 2005.
It has a constant misfire. I know nothing about common rail diesels but have a good base knowledge of cars.How can i determine which cylinder it is I have tried removing each injector electrical connector 1 at a time and it cuts out completely. i have also tried easing of the injector pipes at injector with engine running but again it cuts out completely.
I replaced all the rockers and hydraulics last year after a cambelt failure and the car has run fine for over 3000 miles? I bought these from a very reputable supplier.
I cant hear no air leaks or strange noises....
If i leave it to tick over it sometimes purges???
Any advice before i strip off the cyclinder head?
Many thanks in advance
Nick
Old Jan 30, 2013 | 10:37 AM
joker2cv's Avatar
Error codes??
Old Jan 31, 2013 | 09:45 AM
nicksmith's Avatar
I dont have a code reader.
Just need some ideas on how to isolate an injector so i can determine which cylinder is not firing
Old Jan 31, 2013 | 10:55 AM
joker2cv's Avatar
You can't. In this case an OBD reader is needed...
Old Jan 31, 2013 | 12:11 PM
nicksmith's Avatar
Thanks Joker
Old Feb 1, 2013 | 03:17 PM
tfb's Avatar
tfb
at idle the pressure in the fuel rail is about 3500psi. Cracking the fuel lines is a very dangerous thing to do.
You could measure the voltage to each injector while the engine is running and measure the electrical resistance of each injector. If you find a marked difference on one then that should tell you something.
A leak back test would also show a failed injector
Does it sound odd when cranking over?, if you have access to a oscilloscope and current clamp you can measure the relative compression of the cylinders by looking at variations in current draw.
Regards
Richard
Old Feb 14, 2013 | 07:28 AM
nicksmith's Avatar
FAULT FOUND AND RESOLVED.
It was a faulty hydraulic tappet, even though i replaced all 16 only as few months ago. so complete strip down again.
Done it in less than a day. Just waiting for the out come from the manufacturer. As to why there was a failure of the tappet.
As for the high pressure's thank you for your advise...
You live and learn.
Old Feb 14, 2013 | 02:57 PM
Default Miss-fire on 2.8CRD..
Ah Nicksmith,
Another after repairs fault appears. Good thing you mentioned the work that you had done as I was just going to bring it up. You can always depend on the guys on here giving ideas and and possibility of you/someone throwing away money to find fault.
Goggs.
snake7247
Apr 28, 2014 11:14 PM
Mick
May 31, 2013 05:57 PM
SpectorV
Mar 14, 2012 02:06 PM
marko500
May 4, 2011 02:31 PM
nick v6
Aug 9, 2010 03:16 AM
