2.8 CRD Radiator replacement instructions/guide
Old Feb 19, 2014 | 06:48 AM
Navster75's Avatar
Default 2.8 CRD Radiator replacement instructions/guide
Hi, I have an Voyager 2.8 CRD and it needs a new radiator. Does anyone have a guide on how to do this myself?
Old Feb 19, 2014 | 12:14 PM
Leedsman's Avatar
In a word, no! I paid someone else to do it. He said it was a pig of a job. Be sure you replace the antifreeze with HOAT type in 50/50 solution. Comma make "Go-5" which is the right one. Almost certainly you'll find the thermostat is jammed open (as it is arranged to do with overheating). While it's all apart, makes sense to test it at least.
Leedsman.
Old Feb 20, 2014 | 09:07 AM
Navster75's Avatar
Thanks for the advice.
Old Feb 21, 2014 | 03:57 AM
tfb's Avatar
tfb
not done one myself, but the procedure is in the service manual and 7a - 20 and can be found here Index of /pub/chrysler-dodge/manuals/Service Manuals/2005_RG_Town&Country_Caravan_Voyager_Diesel_Versio ns_Include
Regards
Richard
Old Feb 21, 2014 | 04:16 AM
Leedsman's Avatar
BTW, if the 'stat IS jammed open, you can save money by adopting my "Fitting a second thermostat" posting which appears to be helping members to fix poor heater problems etc. currently. This second 'stat costs around £5.
There is another factor -- one member here replaced his original 'stat following all the proper procedures, only to find it started leaking later. Is this a case of "letting sleeping dogs lie"?
Leedsman.
Old Feb 23, 2014 | 12:34 PM
Navster75's Avatar
Thanks for Service manual guide. Going to attempt to replace this week.
Old Mar 22, 2014 | 06:12 PM
Snoopy123's Avatar
Not done radiator
Done thermostat at week end it was stuck open and aux heater constantly on and temperature never gone up more then a quarter
Took me 3 hours remove wiper blades and wiper motor support. remove air filter housing and to have more space around the thermostat remove the hose from air filter to turbo (access to clip around the turbo from under side removed under cover)this will give you plenty of space to work around the thermostat not difficult just time consuming
Hope this helps
chrysler2001
Dec 30, 2014 11:48 PM
chamuko1967
May 3, 2010 11:32 AM
96SebringJxi
Oct 28, 2007 11:26 AM
afmedic911
May 10, 2007 02:31 PM
CKdoubleU
May 8, 2007 09:09 PM
