2004 Grand Voyager light switch illumination bulbs help!
Old Mar 26, 2014 | 07:14 AM
Dan0678's Avatar
Default 2004 Grand Voyager light switch illumination bulbs help!
Hi, i have a 2004 Grand Voyager and the lights that light up the light switch panel are not present, im having trouble tracking some down an also what sort go in there. Could anyone tell me which type an where i could get some from?
Im in the uk
Old Mar 26, 2014 | 11:19 AM
Leedsman's Avatar
Try Maplins, Radiospares, A.C. Farnell in that order. You'll need to find the type of lamp, eg. MES (Miniature Edison Screw), bayonet type, side contact etc., apart from the voltage which is likely 12volt nominal. There are lots of them! I even have some micro-miniature bayonet type I 'acquired' when I worked for Tandberg that are about 3mm. long. A sample to show the supplier is a good idea, otherwise a picture from a service manual. If you can find a scrapper you could raid it for lamps.
Leedsman.
Old Mar 26, 2014 | 01:28 PM
Dan0678's Avatar
That's the thing I don't know what type fits in as there is no bulbs there.
Thanks for the reply, will carry on finding out.
Old May 23, 2014 | 07:18 AM
Oxford's Avatar
Any luck with this? My light switch/ headlight leveller/ dimming switch doesn't light up. Is this the same bit as yours?
Old May 23, 2014 | 07:41 AM
is your friend. http://www.superbrightleds.com/moreinfo/subminiature-bulbs/pc74-led-bulb-instrument-panel-led/219/
- You should double check the above yourself, I invested just enough time to show you where to look for info, best of luck !
Old May 23, 2014 | 09:20 AM
Oxford's Avatar
Thanx for replying so quickly but unfortunately it's not the cluster as shown on the vid. It's the switch panel that the headlight dial is on. Also the door buttons. I think there's been a distinct lack of maintenance on my GV. I've only had it a week so I'm trying to iron out a few ****les.
Old May 23, 2014 | 04:15 PM
My answer was to [#1] Dan0678 whose question was about the bulb type
In your case Oxford, if you have tested the switch and the switch is definitely faulty go to a scrappers or get a warranted second hand one for £20 here. If you mean all the door buttons and dials are out are you sure its not just the dimmer is switched completely off. Best of luck M8 !
Old May 24, 2014 | 04:40 AM
Dan0678's Avatar
Hi QinteQ no luck yet until now, thanks for that I will investigate further
pervoy98
Oct 2, 2014 02:34 AM
Vmaxxer
Jul 25, 2014 03:08 AM
GrahamLemon
Mar 4, 2013 06:54 AM
SpudlerT+CTouring
Mar 22, 2012 11:30 PM
rattle_au
Jan 27, 2010 06:08 PM
