2005 2.8 Grand voyager starting issues
Old Oct 20, 2018 | 04:16 AM
Nick Smith's Avatar
Default 2005 2.8 Grand voyager starting issues
Good morning.
The car above is starting on the key runs for about 5 seconds then cuts out. I have used both keys and both do the same.
it is like when you use a non chipped key.
once started and stopped if I try to start again it just turns over. However if I lock and unlock the car it starts for 5 seconds then cuts out?
any ideas on testing would be helpful or any similar problems any one had.
thank you
Old Oct 21, 2018 | 08:38 AM
I had the same problem after fitting a new fuel filter. The new filter wasn't sealing properly and was leaking diesel thus allowing air in. It would start and run for just a few seconds then cut out.
John Norrish
Mar 11, 2016 01:34 AM
Jac Borthwick
Apr 10, 2014 09:55 PM
K3nshi
9
Jan 1, 2014 01:34 PM
discojohnno
Dec 20, 2013 06:22 AM
Oil rag
Nov 5, 2013 02:34 AM
