2013 T&C coolant leak in rear
Old Aug 16, 2018 | 07:46 PM
Amakrod's Avatar
Default 2013 T&C coolant leak in rear
I have a 2013 T&C and yesterday noticed the AC stopped putting out cold air. As I looked around the car I noticed that there was coolant leaking from the rear passenger side.
not sure if this is a AC issue or a heater core issue.
Has anyone experienced something like this? I have read about the leaking coolant lines, but not about leaking coolant lines and AC not blowing cool air...or is this one in the same issue?
cant tell if its. Coolant line heater core or evaporator...any ideas?
Old Aug 17, 2018 | 04:41 AM
Taronga76's Avatar
Is the trunk floor carpet wet at all?
Old Aug 17, 2018 | 04:09 PM
Amakrod's Avatar
no it doesn't seem to be wet at all.
when I looked under the van, I noticed that the drips were of a green colour. Thinking it was fluid from the heater core or the coolant line to the back heater core. I checked the rad fluid level and it was normal, but the fluid is red. So I was thinking the green fluid is the oil that us added to the ac system. Is that possible?
Old Aug 17, 2018 | 07:09 PM
georgef's Avatar
Originally Posted by Amakrod
...So I was thinking the green fluid is the oil that us added to the ac system. Is that possible?
It is my understanding that the A/C system comes from the factory with fluorescent dye, which is green in color. So your leak is most likely the oil from the A/C.
Old Aug 17, 2018 | 08:17 PM
Amakrod's Avatar
how can I figure out if the leak is due to a faulty rear evaporator or a leak in a pipe itself?
Old Aug 17, 2018 | 08:19 PM
Amakrod's Avatar
or I should say is there a way to figure out if the leak is due to a faulty rear evaporator or a leak in a pipe itself?
JaxJim
Nov 22, 2015 12:16 PM
boehmex5
Sep 19, 2012 02:49 PM
Don's '99 300m
Apr 27, 2011 08:34 AM
chryxkirk
Jan 31, 2011 05:50 PM
fibersport
Feb 7, 2008 01:02 AM
