2015 AC Problemas
Old Aug 5, 2019 | 08:11 AM
Hotstuff21's Avatar
Default 2015 AC Problemas
2015 Dodge Cara R/t 3.5l
Low side 80 psi at engine off with engine temp 195. Low side pressure 35ish at idle engine temp 195. Car idle at 3k low side pressure drops to 15+/- engine temp 195.
Rear air warm, passenger air warm, drivers side coolest.
Low on gas? Opinions needed. What should low pressure read at idle?
Old Aug 5, 2019 | 02:41 PM
boatmoter's Avatar
with your gauges,hi & low sides connected, turn air on,rev engine,see if low side goes to 0,if so,the Expansion Valve is defective, if system is working correctly, hi side will be bout 175 - 180, low side, 30-35 at an idle, have to know what the hi side is doing
michael-in-tx
Oct 12, 2020 11:45 AM
kkc
17
Aug 29, 2015 12:32 PM
ahd929
Sep 26, 2011 07:03 PM
ghostch15
Jun 6, 2010 04:19 PM
Met-AL
Apr 3, 2009 03:24 PM
