99' T&C 2 wheel drive overdrive downshift trouble
Old Oct 1, 2009 | 12:46 PM
jimi55lp's Avatar
Default 99' T&C 2 wheel drive overdrive downshift trouble
My van is 3.8 engine with overdrive automatic,and it started downshifting late after stop with a hard bump. It feels like someone tapped the back bumper when it sellects low gear wether your in overdrive or 3. I had an Actron diag. code reader hooked up at Autozone which said the transaxle control module has malfunctioned and theinput speed sensor 1 circuit malfunctioned with explanation ECM has detected that the input speed signal changed suddenly. I don't know if I should change the sensor or where it is located on transaxle.
Old Oct 1, 2009 | 02:56 PM
22chrysler's Avatar
OK, first autozone is totally useless when it comes to diagnosing trannies.
You MUST use a scanner with data stream capabilities.
However is your transmission shifting normally up and down except for comming to a stop? if so, your problem is an internal issue knows a bump stop. it is related to the Low/Reverse piston.
mabramsjf
May 16, 2011 01:39 PM
b_ron007
Dec 15, 2010 10:05 AM
tristate
Oct 15, 2010 08:49 AM
Cirrus92
Aug 23, 2009 10:10 PM
muttley925
Sep 29, 2008 03:21 AM
