backfire upon hard acceleration
Old May 12, 2008 | 12:38 PM
davet's Avatar
Default backfire upon hard acceleration
2000 T&C 3.8, 111,000 miles. Starts fine, still has plenty of power however upon hard acceleration from a stoplight it bucks and backfires as if 2 plug wires were crossed. No check engine light and no pending codes. If I'm on the freeway and the RPM's are up I can give it full throttle and it wont do it. It seems to backfire more severely when its under the most load. The backfiring seems to be a popping under the hood, not out the pipe. Sounds like when I had the distributor off 180 degress on my '56 ******. I haven't done any recent to work to it. My wife just came back from a 400 mile road trip and now I notice it. The GPS did show that she it 87mph at one point. I already talked to her about that though. Thanks
Old May 12, 2008 | 01:20 PM
I wonder's Avatar
Default RE: backfire upon hard acceleration
after the backfire, the engine still runs?
it doesn't shut off?
for a start, 2 possible causes for that.
lean mixture and spark jumping due to weak and old spark cables.
renewing spark plug cables would be the first thing I would do. of course, assuming you changed spark plugs regularly and they meet chrysler requirements.
Old May 23, 2008 | 09:12 AM
davet's Avatar
I'm just now getting to check the reponses and you were right. There was no CEL but a pending code showed misfire #2. Pulled the plug and it was fine. Turned the lights off in the garage and started it up but didn't see any arcing until I put my hand by the coil. The #5 plugwirewas cracked and the coil terminal was all carboned up. I replaced that wire and all is fine. I don't know why it showed misfire on #2 tho. Thanks.
Old May 23, 2008 | 12:17 PM
I wonder's Avatar
glad it helped.
if you ever find out why cyl. no 2 was at fault, please share.
Old Jul 3, 2021 | 06:58 PM
MrNaphan's Avatar
Originally Posted by I wonder
glad it helped.
the ignition type of these minivans is called a waste spark ignition so 1 coil fires 2 cyl, one +polarity the other -polarity, while one is in compression stroke the other is in exhaust stroke. the spark that happens in the exhaust stroke is a wasted spark hence the name. #2 pairs to #5, #1 pairs to #4, and #6 to #3. so when one cyl has an issue it generally causes issues in the other. So while #2 was shorting to ground the #5 was experiencing voltage issues caused by #2. the pcm monitors ignition voltage feedback. so it mistakenly thought #5 was the problem but in reality it was a side effect of the problem.
BsMommy
Aug 20, 2011 11:16 PM
robbiedog
Jul 19, 2010 10:00 AM
chrisunwin
Apr 11, 2010 03:08 PM
iivllxpx
May 11, 2008 12:21 AM
adrake
Jul 19, 2007 05:31 PM
