Camshaft position sensor spacer, what to use?
Old Jul 19, 2021 | 08:44 AM
TomasL's Avatar
Default Camshaft position sensor spacer, what to use?
I need to remove the timing cover on my 2010 3,8l T&C
In doing so, the Camshaft position sensor has to come out.
When refit it, ther should be some sort of "paper" spacer at the end.
Any suggestions on what to use, since I dont have the proper spacer available.
Old Jul 19, 2021 | 05:39 PM
FIREM's Avatar
OEM Spacer is about .030" thick. I used 2 match book covers attached with a glue stick. Worked well.
Old Jul 20, 2021 | 02:52 AM
TomasL's Avatar
Ok, so that equals to 0,762 mm.
Old Jul 27, 2021 | 03:30 PM
TomasL's Avatar
So, I took a sheet of laserprinter stickers, put 8 of them on top of each other, giving me a thicknes of around 0,75mm, used a 10mm hole punch to create a cirkular sticker, cleaned the sensor and sticked it on.
Cargal
Jan 6, 2015 01:50 AM
Mrbrucie22
Dec 15, 2014 08:16 PM
sumncguy
Apr 17, 2012 07:27 AM
manshack_one
Dec 13, 2010 06:59 PM
04300special
Aug 13, 2007 09:15 PM
