A/cond Compressor
Old Mar 21, 2012 | 11:45 AM
Huggy59's Avatar
Default A/cond Compressor
Hi all,
I need an advise on my Chryler Grnd Voyger,3.3l,V6, yr 2000.
I've replaced a brand new compressor sometime in Sept 2011. Last weekend,while driving with d A/cond "ON" suddenly I a squeking like sound suddenly appear thru d engine.
When I accelerate again,d sound came up again.
I then tried to "OFF " d a/cond n d sound dissapear n continue driving.
When i on d a/c again,d sound appeared again.
I was told by an a/c mechanic that it cud due to d FAN,which might be faulty cuz it not functioning properly according to d right speed.
Pls confirm whether tis is true?
If its true n d fan need to b replace,shud d compressor b change as well,tqvm.
Old Mar 21, 2012 | 02:22 PM
TNtech's Avatar
If the fans are not sufficient, the high side pressure will go above a certain threshold and the PCM will not engage the compressor. Likely the compressor took a dump again.
Old Mar 21, 2012 | 03:21 PM
This time make sure u have the right amount of oil in the compressor and system itself
Old Mar 22, 2012 | 04:31 AM
Huggy59's Avatar
Thanks yiu guys,so that sound that i heard when I step on d accelerator is confirmed to be a sound of a KAPUT compressor right.
That shows now I got to replace both d Compressor n d A/C Fan right!
There goes d damage......
rrhea
Apr 22, 2022 05:30 PM
Kav
Other
Aug 7, 2015 07:13 PM
Huggy59
Oct 17, 2011 06:23 AM
airplane fixer
Aug 13, 2011 08:05 PM
rhockley
Jan 17, 2006 08:42 PM
