electric windows
Old Sep 17, 2011 | 07:57 AM
piggy's Avatar
Unhappy electric windows
driverside electric window has stopped working. not sure if it is motors or switch.
any ideas?
Old Sep 17, 2011 | 11:35 PM
TNtech's Avatar
It's the motor.
TNtech's Avatar
NO! It's the switch.....
Old Sep 17, 2011 | 11:36 PM
TNtech's Avatar
No, i'm sure now that it's the motor ........or maybe the switch.
Old Sep 17, 2011 | 11:37 PM
TNtech's Avatar
Or maybe it's the motor AND the switch....
Old Sep 18, 2011 | 04:45 PM
booke23's Avatar
It's highly likely to be the motor.
Old Sep 19, 2011 | 07:34 AM
voyager_dan's Avatar
it will be the brushes in the motor take the top off the motor long black cover and take a look at the brushes , clean the track with some fine grade wet + dry paper and it should work again the best way is to replace the brushes i went to a breakers took the passenger motor apart for the brushes as the passenger window gets less use
all this can be done in situe with the door card removed
dan
Old Sep 20, 2011 | 04:42 AM
piggy's Avatar
Thanks guys.
Old Sep 24, 2011 | 04:25 AM
piggy's Avatar
dan
hi Dan, thanks for your advice. could you please explain the process in a bit more detail as i don't what a door card is or where its located'
Old Sep 24, 2011 | 05:38 AM
newnut's Avatar
the door card is the inside of the door, the handle and trim you look at! ebay search for a door card and that will show you! hard to explain but blindingly obvious, dont mean to sound patronizing. the motor will then be visible inside the door once this is off, the rest you'll work out while there. i always remove what i need to at home first, to save me time at the breakers as you'll be doing the same thing for a second time, there fore find it easier. also this shows you what tools you'll need to take with you to preform the task! good luck.
Davidstingray
Nov 2, 2007 02:33 PM
ROCCOBONANZA
Jan 2, 2007 02:44 PM
Davidstingray
Mar 1, 2006 08:12 PM
madsabre
Nov 2, 2005 03:23 PM
rwsebring
Sep 13, 2005 06:29 PM
