Electrical Wiring to front washer pump not working
Old Jan 3, 2014 | 08:54 PM
yadog's Avatar
Default Electrical Wiring to front washer pump not working
Hi, We have 2002 T&C, replaced motor pump for front washer. We switched the wire from rear washer and front works using the rear washer button. We know it's the wiring we think? What can we do to remedy the problem and get in back to working right? Thanks!
Old Jan 4, 2014 | 01:07 AM
are u missing power or ground at the washer pump?
Old Jan 4, 2014 | 05:08 PM
Raptor 07's Avatar
I'm guessing you swapped connectors not "a wire" correct?
Pin #1 (brown wire) is the ground from the Front Control Module (FCM). A switched ground not constant ground
Pin #2 (orange/pink wire) is power from the Integrated Power Module (IPM).
Old Jan 5, 2014 | 09:33 AM
yadog's Avatar
Yes, we swapped connector's. Can a connector be replaced? We think it is a wire at the connector at the front pump since switching produced power and it worked using the rear wash button. Or could it be further down the wiring? How do do you check this? With a meter?
Old Jan 5, 2014 | 09:40 AM
yadog's Avatar
We do not know if we are missing power or ground.
Old Jan 5, 2014 | 04:48 PM
Raptor 07's Avatar
Yes, connectors can be replaced. Is it the connector? Wiggle it. Does the pump turn on? Gently tug on the wires at back of the plug. Do they pull out? If you have two no answers it's not the plug.
You'll need a meter to check the wiring. $15 at Walmart, Sears, Rad Shack, many auto parts stores. Check for power and ground at the pins stated above. If you're missing one or the other you'll have to check wire continuity from the IPM to the pump using the resistance (ohms) function. It won't be a fuse. One fuse safes both pumps.
hotcharity95
Nov 29, 2011 08:56 AM
piersleigh
Feb 12, 2010 01:29 AM
98concorde
Aug 19, 2007 06:51 PM
LT102
Dec 29, 2006 02:52 PM
b350m
Dec 1, 2005 09:31 PM
