Hi all! newbie needing second opinion !
Old Oct 30, 2013 | 10:58 AM
DaveB69's Avatar
Unhappy Hi all! newbie needing second opinion !
Hi all, I REALLY hope there is someone out there who can help me?
I have a 2001 CRD 2.5 diesel with 92000 on the clock, thats throwing up the good old P1130 code,
now, ive been through all the threads relating to this, and i can tell you what i have done to try and correct this, here goes!
Changed fuel filter, checked housing for leaks.
Checked in tank pump and filter, all good.
Checked all fuel lines, replaced the section from the top of the engine to the H/P pump with clear, no air bubbles.
Checked voltage from fuel pressure sensor 1.19v at idle,2.31 at 3,000 rpm, i have changed the sensor for a new one and these readings are from that.
Bosh refurbed injectors, the old ones took a 20ton hydraulic jack to remove
and its STILL stalling under heavy throttle openings or under load and P1130 keeps coming up.
the only thing i can think of now is the H/P pump itself if so, how easy is it to change? has anyone got a manual for this? if so can i borrow please!!!! grovel grovel as finding one that covers the crd engines has proved impossible!
if there is anyone that can help i would be eternally grateful as i really like the old girl and would hate to get rid.
Old Oct 30, 2013 | 11:17 AM
travelmad's Avatar
u will find manuals for the crd here
https://www.chryslerforum.com/forum/...-manual-17113/
Old Oct 30, 2013 | 11:39 AM
DaveB69's Avatar
many thanks for that! have downloaded already
any ideas if its the H/P pump? or have i missed something ?
Old Oct 30, 2013 | 12:28 PM
DaveB69's Avatar
Ah ha! could it be the lift pump thats part of the filter housing? as when its operating you can hear a noticeable whine/buzz type noise from inside the car thats quite loud
Old Oct 30, 2013 | 03:26 PM
Just got to say that this fault of cutting out under load is not new on this forum and if you read back you may get the answer.
Old Oct 30, 2013 | 03:51 PM
Go back to page 3 under 2008 Voyager cuts out when accelerating. Yes right enough P1130 relates to fuel rail pressure fault, not enough pressure on rail under acceleration. Fuel filter housing with internal heater was always the fault but you seem to have sussed that. But in this instance flb (think) found wire 60 from ECU to fuel rail with high resistance. Give it a read as he went through everything....
Old Oct 30, 2013 | 04:00 PM
Aaaaah its tfb and Richard....My profound apologies as he seems to be very helpful...
99TandCMN
Apr 16, 2018 05:25 PM
jeff76
Feb 21, 2012 03:29 PM
41highlander
Jan 31, 2012 06:07 AM
nevergoingtobuyoneagain
Jul 12, 2011 05:16 PM
Raven
Mar 25, 2008 09:47 AM
