Hvac controls & switch illumination
Old Sep 15, 2010 | 11:56 AM
moparrh's Avatar
Default Hvac controls & switch illumination
The heating & air conditioning control panel bulbs can be replaced with radio shack #272-2254. The bulb for the mirror switch can be replaced with #272-1092. You will have to carefully remove the sleeve on the bulb & re-use the twist in socket. Heated seat switches & some other switches will also take #272-2254. If your not handy with a soldering iron, take it to an electronics repair shop. I doubt they would charge a great deal. Hope this helps.
Old Sep 15, 2010 | 12:08 PM
moparrh's Avatar
[quote=moparrh;40800]The heating & air conditioning control panel bulbs can be replaced with radio shack #272-2254. The bulb for the mirror switch can be replaced with #272-1092. You will have to carefully remove the sleeve on the bulb & re-use the twist in socket. Heated seat switches & some other switches will also take #272-2254. If your not handy with a soldering iron, take it to an electronics repair shop. I doubt they would charge a great deal. This was done on my 2001. Hope this helps.
Old Sep 28, 2010 | 04:37 PM
xjr41's Avatar
Hi,
I also need to replace the bulbs in the switch panel. Can you advise the spec of the bulbs as we don't have a radio shack in the UK and I would need to know current etc to be able to source replacement bulbs.
Thanks,
Steve.
Old Sep 30, 2010 | 08:12 PM
moparrh's Avatar
Default Hvac & switch bulbs
THE BULB FOR THE SWITCHES IS 60mA. BULB TYPE T-1. BRIGHTNESS .15MSCP. LAMP TYPE 7219. BULB FOR HVAC CONTROLS IS 50mA. BRIGHTNESS .12MSCP. BULB TYPE T-1
Old Oct 1, 2010 | 07:12 AM
rodger's Avatar
Hi
I got bulbs and LED from Maplins in UK
https://www.chryslerforum.com/forum/...ad.php?t=10916
Old Mar 17, 2011 | 04:03 PM
big walt's Avatar
Which switches are you referring to and which bulbs for the HVAC controls are you talking about. i believe there are two different types of bulbs in the HVAC control. I ask this because most of mine are out too.
Old Mar 18, 2011 | 11:08 AM
moparrh's Avatar
Bulbs are for the hvac controls, not the amber l.e.d's. Switches are the mirror, headlamp, heated seat swithes etc.
Old Mar 18, 2011 | 05:05 PM
rodger's Avatar
Hi
My response is for the centre console "Icon" bulbs ie.not the rotary yellow "volume" leds.
I also replaced the hazard light with an led.
It's not that hard a job.
Old Mar 25, 2011 | 04:47 PM
barwaryzaid's Avatar
Originally Posted by rodger
Dear i just would like to know what year is you car I am in UK as well I have grand voyager 54 problem with illumantion I just would like to know what year is you as far is i know in new model they are not replacable
please help
darkcild101
13
Jul 30, 2015 08:08 AM
xtremez28
Dec 11, 2014 11:33 AM
Vmaxxer
Jul 25, 2014 03:08 AM
Dan0678
May 24, 2014 04:40 AM
GrahamLemon
Mar 4, 2013 06:54 AM
