Intermittent Oil Pressure light problem 2010 2.8 diesel
Old Mar 27, 2018 | 05:29 AM
Abbo69's Avatar
Default Intermittent Oil Pressure light problem 2010 2.8 diesel
Hi all.
After going back and forth to my local regular mechanic and then main dealer, I've been trying to find out about my oil pressure light problem with little result, so I've joined this forum as a new member to see if anyone can shed any light.
I have a 2010 Grand Voyager 2.8 diesel that's covered about 42000 miles. When I start it from cold the warning light does not come on during idle but will illuminate at around 1500-2000RPM when I start driving (or 2000RPM in neutral). The light will go on and off at various stages during a journey but then stops once up to normal running temperature.
So far local mechanics have changed the oil pressure switch twice and were then reluctant to help again, suggesting I go to main dealer.
Main dealer checked oil pressure and said they had found some bare wiring which they taped up, changed a brake light bulb to road test and then charged me handsomely for.
This did not rectify the problem, as when I started from cold again the light came on at the higher RPM's again.
Can anyone suggest any possible causes please?
Many thanks in advance.
Y4J
Jan 31, 2023 06:33 AM
GlennDenise
Jul 29, 2020 10:05 PM
kythri
Aug 19, 2017 10:53 AM
billbon8
23
Jul 18, 2011 04:48 PM
gbwiii
Jan 6, 2009 03:48 AM
