Brakes
That was with standard discs, calipers and alloys when I got the tyres changed. Had to go back and get the weights removed, and the wheels rebalanced with weights on the outside. There's not much clearence in there.
Others may know of something, but I'm guessing uprated discs and pads might be the best you could hope for.
No idea, because we have no idea what your year is my friend, examples below.
2005
Centre Hole Size (mm): 73.5, Outer Diameter (mm): 301, Overall Height (mm): 39, PCD: 114.3, Thickness (mm): 28, Minimum Thickness (mm): 26.5, Fitting Holes / Studs: 5
2008
Centre Hole Size (mm): 72.6, Outer Diameter (mm): 305, Overall Height (mm): 33, PCD: 127, Thickness (mm): 12, Minimum Thickness (mm): 10.5, Fitting Holes / Studs: 5
2005
2008
