Loosing Coolant
Old Feb 5, 2018 | 06:36 AM
ymohamed@randmutual.co.za's Avatar
Default Loosing Coolant
Hi, I have a Chrysler Voyager 2.5 CRD Diesel. Daily I need to top up coolant with approximately 3 pints. I cannot see any visible leaks. No coolant on the garage floor. The temperature gauge mostly is around the middle and occasionally goes up to the 3/4 mark. The radiator fan does not seem to switch on. The fuse / relay for the radiator fan seems fine. The oil does not look murky. What could the issue be?
Old Feb 6, 2018 | 03:12 PM
Bleed the coolant system properly. Get the air out of the top hose/metal pipe. And check Auxiliary heater for coolant at exhaust flexi.
Old Feb 11, 2018 | 07:37 AM
dieselvoyager's Avatar
The temp gauge in a CRD never goes up to 3/4 this time of the year , Max 1/2 wich is normal in summer time , in winter time it might be a little lower. "measure needle wide"
How about the coolant pipe to aux heater , Thay can be very rusty and a small leak could just evaporate weil driving .
Old Feb 11, 2018 | 08:10 AM
A piece of this gives a temp fix and will move (1) the temp gauge from 1/4 to 1/2 and will shorten by 50% the driving time needed to reach that 1/2 on the gauge [can be dismantled in milliseconds] buy new stuff next winter or pop it in the boot if your middle name is Ebenezer - get the correct diameter size, you will need x3 pieces for a fully covered dam !
Old Feb 13, 2018 | 06:32 AM
Bee's Avatar
Bee
Hi guys.
I had this problem for about 18 months I disconected the Aux heater and I've had no trouble since. But I will say it was a bit of a pig to blead the system.
latreto
May 20, 2012 06:34 PM
chrycon
Oct 16, 2010 09:25 AM
jquinones
Dec 4, 2008 01:54 PM
shadetreemech
Apr 12, 2008 09:08 AM
fibersport
Feb 7, 2008 01:02 AM
