Oil Viscosity for Pentastar 3.6 engine
Old Jul 23, 2019 | 07:51 PM
steveatpa's Avatar
Default Oil Viscosity for Pentastar 3.6 engine
I have a 2013 T&C (3.6 engine) and 5-20 is the recommended viscosity. I'm OK with using a lighter weight viscosity but...this engine can run HOT in stop and go traffic whereby the fan comes on at 217* and the engine oil climbs to 200*+. Why so hot...? Plus after changing the oil I've noticed that it can consume almost a quart of oil in 3000 miles. That seems excessive for an engine with only 30,000 miles on it.
So my question is, has anyone tried a heavier viscosity and was there any noticeable benefits or negative affects? Thanks...
Old Sep 9, 2019 | 04:45 AM
Smokey0210's Avatar
I’ve always wondered that too, but I’d honestly stick with the 5w-20. I don’t know if your under any powertrain warranty, but if you use the wrong oil and that was found to be the cause, I would imagine they’d deny your repair.
Old Sep 23, 2019 | 07:17 PM
alex5357aa's Avatar
Try to change the Thermostat ( easy job ) from wrangler 3.6 180F.
abacab
Dec 17, 2017 06:07 PM
COPPERDOG
Dec 3, 2013 02:53 PM
Hodges710
Jul 13, 2013 06:41 PM
Hodges710
Jun 28, 2013 03:23 PM
Lady
May 26, 2008 01:56 PM
