Open message to Qinteq.
Hi Qinteq, have a look at this....
http://www.pvv.org/~syljua/merc/TooSeptST07.pdf
I'd value your opinion on this discussion about alternator hash and its effect on electronic systems various.
I've also made a little plug-in charge checker to insert in the cigar lighter using a 12v. zener, a silicon diode and a hi-bri red LED. It has revealed the alternator output is far from smooth, by constantly flickering which it didn't when I put it together in the workshop using my workshop's battery. Hence the interest in alternator hash as above. It just dawned on me that a DVM or analog meter wouldn't show this voltage instability (sample and hold effect in the DVM, mechanical inertia in the coil and needle in the analog).
I'll post a piccy and circuit on here if you want.
Leedsman.
Leedsman.
And here's another concerning the effect of starter-motor power drain on microprocessor based memory-dump.
DC Power Onboard with Newmar’s DC Power Conditioners. Newmar’s power array of dc conditioners provide stabilizing voltage during engine crank, voltage stabilizers with Isolated DC-DC converters, electronic noise filters and automatic powe
Leedsman.
Leedsman.
This is set for 14.4volt charging, if the system is still on the lower voltage, just eliminate the silicon diode. If you like a green LED also eliminate this diode as the firing voltage for green is higher; but the red is more efficient.
Leedsman.
Leedsman.
dphickster
May 5, 2008 09:00 PM
