P0304 cylinder 4 misfire
Old Oct 24, 2024 | 09:31 PM
Banjo's Avatar
Default P0304 cylinder 4 misfire
I have a cylinder 4 misfire on my 2014 Chrysler town and country.
I have a check engine light with a code P0304 and that is the only code showing.
The only symptom I have noticed is there is a sight shake when at a stop, or when driving below 5 mph.
I replaced the coil and spark plug on cylinder 4, and initially thought the issue was fixed but after driving it a little the shake came back and the light came back on.
Any ideas on what could cause this, or how to troubleshoot the issue?
Thanks for any help!
101k miles
3.6 L
6 cylinder
Automatic transmission
Old Oct 25, 2024 | 08:42 PM
check compression in number 4 and others. What is the fuel trim for that bank? are you feeing the miss or just the lite comes on?
Old Oct 26, 2024 | 09:07 AM
Banjo's Avatar
thanks for your reply. Ill get the compression checked. To be honest I’m not sure what fuel trim even is, it feels normal when first driving it, but after a while you can feel it start to shake when breaking, and accelerating but only at the lower speeds.
im not sure if the shake counts as feeling the misfire but that’s all I can feel that’s off
mangagurl
Jul 30, 2024 03:02 PM
blazeodin
Mar 23, 2022 09:42 AM
Nardy30
May 18, 2021 11:07 AM
jimi1952
Feb 19, 2014 02:22 PM
cjhstang
Sep 18, 2009 10:52 AM
