Power window issue
Old May 20, 2019 | 04:32 PM
Whatever Everybody's Avatar
Default Power window issue
Hi...newbie here,
Having an odd problem with my driver's side power window, It will _always_ roll down but usually never rolls up on the first try. And, at times, it just wouldn't roll up at all.
I have replaced the switch cluster 2-3 times and, each time, the window works perfectly for a few months then will start having the same issue.
Any ideas?
Thanks in advance.
Joe
2006 Chrysler T&C Touring
Old May 21, 2019 | 03:50 AM
Next time it happens, try thumping the door card in the middle a few times with your fist while pressing the switch. If the window moves then it indicates that you need new carbon brushes in the motor.
Old May 21, 2019 | 06:07 AM
REBEL59's Avatar
Agree'd with you. I have also found that spraying the glass tracks periodically with silicon spray helps and also taking the "DOOR CARD" off and lubing the lift cables the motor works to move the glass very helpful also...from a member of many mopar mini vans from the USA side of the "POND"!
Old May 23, 2019 | 08:58 PM
dyear20's Avatar
We had this issue with the passenger side window try to “fonzie” it next time. It work a long time for me and I eventually replace the window motor and track and it’s had no issues for the past 3ish years now
HarleyRob
Feb 28, 2018 12:44 PM
kings322
Mar 22, 2011 03:56 AM
funjon1
Sep 8, 2009 09:08 PM
funjon1
Jul 16, 2009 03:10 PM
funjon1
Jul 12, 2009 06:04 PM
