rear brake caliper locked up again >?`
Old Oct 23, 2013 | 06:36 AM
300winchester's Avatar
Default rear brake caliper locked up again >?`
Just replaced my left rear brake caliper, locking up again, is it caliper or distribution ? any input appreciatied
Old Oct 23, 2013 | 09:03 AM
bigjim31817's Avatar
try cracking the the steel line at the flex hose check to see if caliper still stuck then crack flex hose at caliper if caliper releases replace flex hose
Old Oct 25, 2013 | 03:57 PM
You say you've just replaced it and its locking up. Sounds like the overhauled unit hasn't had the inner seal replaced and piston.
Either take it back and tell them the fault or strip it down yourself and clean it out yourself then rebuild. Course you should find it clean inside.
If not clean inside you have recourse. If clean, rebuild it with preferably new seal (seal must be at fault).
Its all roundabouts here and coming back to faulty Calipher..
Good Luck.
imtattoo80
Jul 16, 2015 01:36 PM
chrysleroh
Apr 18, 2014 03:57 PM
CarComp
Jun 26, 2012 09:18 AM
billdc
Mar 30, 2012 09:00 AM
barrybb
Jun 2, 2009 03:42 PM
