transmission fluid for manual voyager 2003 CRDI 2.5
Old Aug 23, 2014 | 12:12 PM
boyan's Avatar
Default transmission fluid for manual voyager 2003 CRDI 2.5
dear Gents!
can you please advise what specs of transmission oil MUST GO into manual transmission in
CHRYSLER VOYAGER,
2003,
2.5 CRDI,
vin 1C8GYN3713Y547084
as my first and third gear keep slipping out (without any noise) so I am hoping that there is a problem with the oil quality
cheers!
PLEASE HELP!!!
Bojan from Balkans
Old Aug 23, 2014 | 02:14 PM
Vmaxxer's Avatar
Edit: sorry misread your post, i thought you where talking about auto transmission. I dont know if there is any different oil for manual transmission?
Old Aug 24, 2014 | 01:25 AM
tfb's Avatar
tfb
The manual gearbox uses ATF+4 fluid, A fluid change won't do any harm but I'd surprised if it helps.
Regards
Richard
Old Aug 24, 2014 | 05:23 AM
Vmaxxer's Avatar
Found a very good post from übersarcastic user "Glowplug"
https://www.chryslerforum.com/forum/...d-10820/page4/
Old Aug 24, 2014 | 01:34 PM
boyan's Avatar
Default slipping out from first and thirs
dear guys, does anybody absolutely anybody has any idea why my gears are slipping?
I disconnected cables and reached gearbox from under the hood and still slipping + changed oils 4 times in last 3 months + refurbished front engine mount + opened gearbox and inside looks great.
any idea?
PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!! PLEASE HELP!!!!
Old Aug 24, 2014 | 03:33 PM
Just wondering if your cables are stretched and lever in gearbox is not being pulled enough to engage slides/mechanism on detent *****. But you say you have engaged it manually under hood and its still the same. You say you opened gearbox, did you find any loose nuts on end of shafts. The Renault scenic engine jumps out of 5th gear when gears end nut comes loose or falls off.
If all else fails its a Gearbox out job...Try second hand.
Old Aug 25, 2014 | 02:41 AM
tfb's Avatar
tfb
yep, gearbox rebuild or replace
Regards
Richard
voyager200
17
Sep 6, 2013 01:27 PM
kobusven
Jul 30, 2012 11:18 AM
alexnz
May 16, 2012 02:00 PM
farmerbob02
Apr 13, 2011 12:04 AM
GoPaintless
Apr 27, 2010 12:38 PM
