transmission fluid in rad
hi all
i have noticed what looks like transmission fluid in my radiator and filler bottle ihave checked transmissionfluid leveland colourwhich areperfect what could this possibly be it is a grand voyager 1999 i am based in the uk any advice would be great
Many thanks
Dave
Many thanks
Dave
Suggest replacing radiator since the tranny cooler is integral to the radiator. May need to flush cooling system. If there is water in the tranny fluid, the transmission fluid may need to be changed and the transmission flushed. If there is no water in the tranny fluid, everything else is probably OK.
If the transmission fluid hasn't been changed in 50,000-60,000 miles, this would be a good time to change the transmission fluid since you will be addiing fluid anyway to the transmission upon initial start-up to fill the fluid cooler part of the radiator when it is replaced. What ever you do, use the correct Chrysler transmission fluid (According to some literature I read, ATF + 4 is backward compatable with ATF+3) Do not use Dexron in most Chrysler 4-speed automatics unless you want to be looking for a rebuilt tranny.
[align=left] [/align]
ORIGINAL: davidandkeiley
i have noticed what looks like transmission fluid in my radiator and filler bottle ihave checked transmissionfluid leveland colourwhich areperfect.
have checked the fluid in rad and it does look like a milkshake . I have also checked trany fluid on dipstick and that looks ok so i think it must just be getting into the rad not the other way around .Will look into changing the rad my self as i have got hold of the manual on cd but will have to think is it worth the hassle
Dave
Dave
Radiator @ a place like Autozone will run between $200 and $300 depending on which radiator you end up buying/ordering. labor is going to depend on where you live and the flat rate manhours is budgeted for removal and replacement of radiator and accessories.
farmerbob02
Apr 13, 2011 12:04 AM
