Heater blower motor only runs on Hi speed
Old Aug 17, 2005 | 11:37 PM
elpaso's Avatar
Default Heater blower motor only runs on Hi speed
Can any body tell me where to locate the blower resistor?
Old Feb 28, 2006 | 12:59 AM
usdmike's Avatar
Default RE: Heater blower motor only runs on Hi speed
Still need to know bc i do. Im a lil late though.
Old Aug 10, 2006 | 01:34 AM
owbbarnes's Avatar
I am having the same problem with my a/c running only on high. I would like to replace the motor resister and the blower switch. Can you tell me where they are located. I have a 2000 Chrysler Cirrus.
Old Oct 27, 2006 | 10:39 PM
iggy75's Avatar
under glove box by heater vent. take off panel. disconnect wiring connector, this is motor resistor. i replaced mine, but less than a month later, i only had high again. mopar said i could return burnt resistor once, but if that blows also, i have greater problem.
Old Nov 22, 2010 | 06:21 AM
inventor's Avatar
Default Gone through 4 or 5 resistors
What is the solution to this problem, replace blower motor or improve resistor? What fails in the resistor block? Is their a better spec. diode available? Seems if they work for a month they could be beefed up some to last longer.
Old Nov 22, 2010 | 11:56 AM
replace the blower motor resistor if it fails again the blower motor is drawing to many amps and that will need to be replaced
Old Apr 1, 2011 | 07:30 PM
Mary Smith's Avatar
Have 1999 Cirrus - no problems until we have lost all but "HI" on blower speeds. From above posts, seems this is a problem with (at least) the 2000s. Do I need a new part, a take-apart-and-fix service call, or what???
Old Apr 1, 2011 | 10:18 PM
Old Aug 8, 2011 | 05:30 PM
mrm0rgan's Avatar
im not a machanic so take my advise for what its worthi went a whole year and replaced blower motor resistor three different times in my breeze then to come to find out it was the blower motor . so save your self 20-30 bucks or the price of one at a pull yard and just spend the money and take care of the problem and replace the blower motor. i was told it was the blower motor by a machanic and got it replaced and hav'nt had a problem since been about two years.
Debbie Sisk
Apr 30, 2014 02:12 PM
rye2
Aug 31, 2012 09:31 AM
dm6174
Nov 11, 2009 05:39 PM
kunzite
Sep 1, 2009 12:41 AM
elpaso
Aug 25, 2005 01:11 AM
