really need experienced input
Old Jun 16, 2011 | 10:06 PM
justabrit's Avatar
Unhappy really need experienced input
Hi All,
here's my proble.
a 95 cirrus lxi 2.5 v6....battery w3as shot and needed boost to get her running....as i was working on the rear brakes and needed her running to blleed i had to keep her hooked up to my slave vehicle because the battery would not hold any charge....any ways i get new battery and hook her up...now she turns over fine,plenty of power but will not start up....fuel pump kicks in, and not showing any codes other than when batt was disconected...
it is possible i could have just fried something keeping her hooked up when i was doing the brake bleed.....
relly looking forward to imput.
thanks guys
Old Jun 16, 2011 | 10:27 PM
Djinn-n-Tonic's Avatar
First things first.....
Do you have a Tachometer in the car???? It should "BOUNCE " when you crank it.....
Carefully go over the battery cables...... Its easy to "Misplace" a ground strap when Removing /Installing a battery.
Old Jun 17, 2011 | 09:33 AM
justabrit's Avatar
Hi
thanks for reply, i went and looked this morning after what u said.....seems the 2 batt cables are good and tight and they were the only ones that i took off....as for the tachometer.....when i crank her up there is jus a flickering of movement....just a flicker thats all..nothing big at all
Old Jun 17, 2011 | 01:22 PM
justabrit's Avatar
this morning i pulled the fuel line off the rail and turned her over..there was plenty of fuel getting out as for the flicker thing....i pulled the 40 am fuse under the hood for the running lights and as i went to put it back the lights came on...i had the ignition on....but as the fuse went in fully it shut off the left light and the front right started to get the little pulsing flicker again
cleveland63b
Jun 16, 2013 12:08 AM
heartbecca
Dec 22, 2012 07:37 PM
kraichle
Apr 22, 2012 09:15 PM
Gasman
Jan 24, 2011 12:23 PM
BigBlocksnHardrock
Dec 11, 2008 05:28 PM
