Detailing Discuss detailing your ride within...
Outside Cleaning
Old Oct 17, 2007 | 07:39 AM
mikeeyd's Avatar
Default Outside Cleaning
I have a 2007 Pacifica and I would like some advice on cleaning the plastic trim along the rocker panels of the car. It gets dirty from road grime and I cannot find a cleaner to remove the spots and dirt. Thanks for the help.
Old Oct 21, 2007 | 09:36 PM
Psungee's Avatar
Banned
Default RE: Outside Cleaning
We've used tar and bug remover on the bumper (which is, of course, not metal)
Old Mar 12, 2008 | 09:58 PM
Al B's Avatar
Any wax and grease remover should reomve the grime, such as bug and tar remover. There is also Simple Green. A good alternative.
Old Oct 15, 2008 | 04:30 PM
ceazer458's Avatar
If you are referring to the bottom portion of the car....the grey plastic...I use soap and water and then polish it with a UV Protector. Looks line new. Bought this stuff from PepBoys called Professionals Favorite and it's great.
Old Dec 20, 2008 | 09:23 PM
15951a\'s Avatar
You need a good bug and tar removal. The best I've used lately is made by Surf City Garage, and it's called Road Trip Grime Destroyer. Sounds hokey, but works amazingly well.
Follow up with a good exterior protectant if this is an unpainted panel. Certain sealants can be used on those panels, which will help keep them clean. Zaino is the best, IMO, but there are others. Just make sure you don't apply any sealant or wax that stains trim and plastic.
Old Nov 27, 2010 | 05:45 AM
ronaldoyesher's Avatar
Any car soap(not dish soap) will be fine... To scrub use a microfiber soft of sponge... To dry use a scratch resistant towel....It will be better for you.
Old Nov 27, 2010 | 05:46 AM
Any car soap(not dish soap) will be fine... To scrub use a microfiber soft of sponge... To dry use a scratch resistant towel....It will be better for you.Car will be better seems and will be charming.
Old Jan 6, 2011 | 07:07 AM
hebi18812's Avatar
regular cleaning is required for this and any car cleaning agent can be used for the cleaning
xianh
Jan 25, 2010 06:52 AM
SARG
Oct 14, 2008 03:05 PM
lerry1957
Mar 21, 2008 09:36 AM
volly
Mar 18, 2008 02:14 PM
sumncguy
May 19, 2007 01:28 PM
