AutoStick
Old 02-27-2007, 05:41 PM
JVieira's Avatar
Default AutoStick
Hey there..was wondering if anyone could explain how autostickworks. Could someone also confirm that you would use less fuel andif autostick should be used on regular bases?? Also how would you use autostick in winter..I'm having a hard time driving this "baby" in the winter since my tires keep slipping..some one told me to use 2nd gear to start and 3rd gearfor normal winter driving..can anyone either confirm this??
Thanks, Joe.
Old 02-27-2007, 06:27 PM
Default RE: AutoStick
he is right buy taking off in second you dont put that much power to the wheels i have a 04 pac awd and use mine a lot hen you go down steep inclines you can shift down instead using your brakes
Old 02-27-2007, 10:26 PM
autostick is nothing but another way for u to control what gear the trans goes into.The tranny computer will do a much better job of saving u fuel then u using autostick. Its a fun kinda thing a bell and whistle. There are safey built into it though if u are in first and floor it it will automaticly change into second when u redline. Have fun
Old 03-12-2007, 01:46 PM
donnyohs's Avatar
Autostick is fun to drive with, but it isn't really much more fuel efficient. Did you check to see if your tires are bald, bad tires make you slip. I just got new tires and I don't slip anymore. BF goodrich Traction T/A are my recommended, they are direction and are very quite and smoother than stock tires.
aifam55
03-04-2011 05:36 PM
01goldsebring
11-14-2009 10:05 PM
M1Ark
07-24-2009 06:34 AM
Capa
06-18-2007 11:06 PM
JVieira
03-12-2007 01:46 PM
Quick Reply: AutoStick
