Loss of power
Old Jan 12, 2011 | 12:10 AM
tupadjia's Avatar
Default Loss of power
I have a 2000 neon, LE, and recently Ive noticed quite a bit of power loss, especially when I am going up a hill and it takes me 3 times longer to get to the top compared to before.
I changed the oil + filter, air filter and spark plugs (champions). That didnt fix it and further research revealed it might be the ignition coil so I changed that too. Now, there is a bit of improvement but not 100%.
No P codes came up so I am bummed out for now. Anyone point me to the right direction please?
Old Jan 16, 2011 | 01:48 AM
sleepymechanic's Avatar
Hi tupadjia,
If you do most of your work and have all the necessary tools to perform some diagnostics a couple of things to check are fuel pressure at the rail, exhaust back pressure, (restricted cat), and cylinder compression. You'll need the manufacture specs for these checks also, I'm not familiar with your vehicle so don't know if you have an external fuel filter or if it's in the fuel tank but the dealer or a repair manual can give you this info.
Hope this helps!
Sleepy.
Old Jan 22, 2011 | 01:52 PM
tupadjia's Avatar
So it was the catalytic converter that was restricting me from having full horse power. So what we did was take out the cat and out in a replacement pipe. Not only does it sound like a performance muffler but it also hauls ***
DaveSiever
Jun 3, 2014 03:23 PM
tgpatton
Sep 22, 2010 08:19 PM
paul.siwek
Nov 24, 2007 03:02 AM
taffyd
Apr 24, 2007 06:42 PM
ChryslerNamedTrixie
Dec 22, 2005 03:55 AM
