Please help my 73 Satellite Wagon run right
Old Dec 12, 2009 | 07:34 PM
73SatWag's Avatar
Default Please help my 73 Satellite Wagon run right
Hello, so my 73 Satellite wagon has a 318 with a 2BBL Carter carb, and when I got it, it drove home 1 1/2 hours just fine, but after that it would stall out when I gave it gas. I changed the air cleaner, fuel filter, cap, rotor, wires, charcoal canister filter, plugs, and rebuilt the carb. Soon it grew out of that habit and took on a new one; it would only run for a couple of minutes and then die out, not wanting to start again for a while. Once it died, I tried starting fluid and it would fire up again for a few seconds, most likely indicating a fuel problem...so I replaced the fuel pump, which helped a little. So now what it does is idle nicely for 5-6 minutes, the idle rises quite a bit, and then it will eventually die out. Even now, it wont start back up unless I use starting fluid or wait a long time. I am suspecting the choke at this point, since it seems to happen when the car heats up, and the idle changes when the choke moves. Any suggestions on what I should check or how to fix this?
Old Dec 13, 2009 | 02:43 AM
leeb's Avatar
I would suggest a fuel-system-cleanout...
remove/empty/clean out fuel tank/pickup-and-strainer...
ensure new fuel filter (if you havent already)...
Use some gas dryer on 1st restart... just in case some water was/is in the lines...
Hope that helps!
robvia
Jan 6, 2009 11:58 AM
golddog
Jan 16, 2008 10:48 AM
bguerrios
Oct 1, 2007 06:29 PM
Dec 28, 2004 01:29 AM
