94 Chrysler concorde cranks but won't start and headlights flash for 3 minutes
Old 12-07-2018, 05:41 AM
Jholliday420's Avatar
Default 94 Chrysler concorde cranks but won't start and headlights flash for 3 minutes
Car cranks but won't start and the headlights flash for 3 minutes. Anyone habe any idea what could cause this. I've replaced the ignition starter switch check the spark fuel pressure and cam n crank sensors all seem to be fine and still won't start. Help please
Old 12-07-2018, 08:44 AM
REBEL59's Avatar
Wow, that's getting to be an "oldie"! Does this car have a factory alarm/anti theft? The flashing headlights seems to indicate that. And in your workings with it may have activated it. Try a complete battery disconnect for a few hours (some call a hard reset) and then try it....Good Luck!
Old 12-07-2018, 09:43 PM
Battery has been disconnected for 2 days and it still does it. Thanks for the idea tho I greatly appreciate it.
Old 01-02-2019, 12:18 PM
RShoaf's Avatar
I would agree that it sounds like an alarm issue, but it might be an aftermarket.
If a factory alarm it can be shut off by turning either door to unlock with the key.
If that doesn't work, look under the dash for a box with aftermarket wiring. It will have a inline fuse holder on the wiring. Remove that fuse.
Now look at the wires. Two of the wires coming from the black box will be spliced into a wire coming from the factory ignition switch ( lower part of the steering column.)
Disconect the aftermarket wires from the factory wires and splice the factory wires back together. Your car will now start.
iluvdiznee
04-08-2021 10:51 AM
Joi
06-24-2018 09:25 AM
ccdlpd
06-03-2014 04:22 PM
size2020
09-18-2010 11:24 AM
acmectec2001
01-01-2007 06:51 AM
Quick Reply: 94 Chrysler concorde cranks but won't start and headlights flash for 3 minutes
