1998 concorde Instrument cluster lights
Old Jun 15, 2008 | 11:49 PM
jlboan's Avatar
Default 1998 concorde Instrument cluster lights
Hey guys, I have a 1998 Concorde LXi with the 3.2L v6, and the lights that illuminate the gauges will not come on. Also, the arrow lights for the turn signals no longer work. The indicator lights work fine, such as the oil, airbag, and hi-beams. But all of my gauges are dark and I can't see how fast I'm going at nighttime. I checked all of the fuses, and pulled two extra headlight switches from the junkyard. I hooked up the other switches but its the same problem. The odometer and gear indicator lights dim as normal when the headlights are turned on. Any ideas or help? or am I stuck buying a different instrument panel?
Old Jul 26, 2008 | 09:28 PM
Twiztid_psychokiller's Avatar
Default RE: 1998 concorde Instrument cluster lights
Try taking out the cluster and checking the little light bulbs in it i had a mercury cougar that did the same thing and that was the problem could work for you to
clt72pilot
Sep 6, 2016 05:19 AM
jtg61
Jul 19, 2012 06:07 PM
skierman627
Jul 8, 2010 11:45 PM
Scruffy
Oct 12, 2009 09:19 AM
ringalori
Apr 1, 2009 11:37 PM
