96 jxi alternator belt tension adjustement
Old Feb 3, 2014 | 10:17 AM
noasinc's Avatar
Default 96 jxi alternator belt tension adjustement
There is an adjusting bolt under the belt tension pulley. When I am turning it in or out it does nothing to the tension of the belt. I need to remove the alternator and have it bench tested. What should I do to release the tension w/o damaging anything?
Old Feb 4, 2014 | 12:59 AM
because there is a second bot u must loosen first then the adj bot will allow it to move
Old Feb 4, 2014 | 08:45 AM
noasinc's Avatar
where is that second bolt located? Please be specific, there is very little room and hard to see.
Old Feb 4, 2014 | 09:28 AM
its on the pulls itself the same on you are turing the adjusting bolt on
Lanatwo
Dec 10, 2013 12:56 PM
Onlylexus
Dec 12, 2010 03:28 PM
Flyguy
Sep 14, 2010 07:55 PM
evigilu
Mar 7, 2008 08:15 AM
mrg60
Nov 14, 2007 01:48 PM
