Why won't my sebring gtc start???
Old May 22, 2017 | 10:19 AM
TLT's Avatar
TLT
Default REPLY: (starter system)
After checking I was informed nothing was changed out or replaced but the crankshaft...still has the Same flywheel and Cam shaft for the Signal between the sensors and the pcm. Thank you for that suggestion. Couldn't see the ECM PCM?
Old May 22, 2017 | 10:23 AM
TLT's Avatar
TLT
Default REPLY: (ignition system)
I was informed nothing was changed out or replaced but the crankshaft...still has the Same flywheel and cam shaft for the signal between the sensors and the pcm. Thank you for that suggestion. Could it be the ECM PCM or something else?
Old May 22, 2017 | 12:53 PM
Not sure what you are saying. In one place, you said the cam and crank sensors were replaced, in another you said nothing but the crankshaft itself was replaced. If they replaced the sensors with the wrong ones, it might explain the problem.
Old May 22, 2017 | 01:58 PM
TLT's Avatar
TLT
Yes the crankshaft was damaged and replaced. Yes the sensors were replaced. I was unaware that you were including the crankshaft and cam sensors when you were referring to the ignition system. I will forward your information and have my technician / mechanic looking to it. Thank you
Old May 22, 2017 | 08:15 PM
  #15
I want to know if they changed the cam tone wheel when the timing chain was replaced? if s then they installed one for a wrong PCM so they get to take it back apart and replace it with the original tone wheel aka gear.
Old May 23, 2017 | 03:13 AM
  #16
TLT's Avatar
TLT
Default Reply:
It has the original tone wheel/gear. That was not replaced.
TLT
May 21, 2017 01:50 PM
TLT
May 21, 2017 01:48 PM
CoolDaddy
Sep 30, 2016 11:46 AM
CoolDaddy
Sep 25, 2016 08:55 PM
scoobygeorge
Nov 23, 2008 07:00 AM
