Why won't my sebring gtc start???
After checking I was informed nothing was changed out or replaced but the crankshaft...still has the Same flywheel and Cam shaft for the Signal between the sensors and the pcm. Thank you for that suggestion. Couldn't see the ECM PCM?
I was informed nothing was changed out or replaced but the crankshaft...still has the Same flywheel and cam shaft for the signal between the sensors and the pcm. Thank you for that suggestion. Could it be the ECM PCM or something else?
Not sure what you are saying. In one place, you said the cam and crank sensors were replaced, in another you said nothing but the crankshaft itself was replaced. If they replaced the sensors with the wrong ones, it might explain the problem.
Yes the crankshaft was damaged and replaced. Yes the sensors were replaced. I was unaware that you were including the crankshaft and cam sensors when you were referring to the ignition system. I will forward your information and have my technician / mechanic looking to it. Thank you
I want to know if they changed the cam tone wheel when the timing chain was replaced? if s then they installed one for a wrong PCM so they get to take it back apart and replace it with the original tone wheel aka gear.
CoolDaddy
Sep 30, 2016 11:46 AM
CoolDaddy
Sep 25, 2016 08:55 PM
