07 Chrysler Aspen has a NO FUSE error message
Old Aug 15, 2013 | 12:01 PM
christyf's Avatar
Default 07 Chrysler Aspen has a NO FUSE error message
My husband and I need some help -- we love you 07 Chrysler Aspen, but have an issue. The car will not start, will not turn over, and has an error message "NO FUSE". My husband discovered that the fuse panel in the vehicle below the steering wheel was wet (we think we have a leak in the sunroof and it's traveling down the door panel).
We don't want to have the vehicle towed, and want to fix/replace the fuse that is out.
Where is the fuse panel under the hood? What fuse would it be?
My husband cleaned off the fuse panel last night and it started this morning, but will not start for me now.
Please help!
Christy.
Old Aug 16, 2013 | 01:18 PM
15951a\'s Avatar
It sounds like you already know what the problem is -- a wet fuse box causing intermittent shorts. You need to get the leak repaired, and pull/check the fuses in the box that was wet.
The same error message can sometimes happen with a dead/dying battery.
edhunt0r
Jul 19, 2023 08:25 PM
DANIELMON
Feb 3, 2011 05:11 PM
berk3066
May 17, 2008 03:38 PM
dphickster
May 5, 2008 09:00 PM
mazdapower3
May 4, 2008 10:34 PM
