2007 Pacifica 4.0 crank no start issue
Old Dec 22, 2020 | 03:12 PM
Tm2k's Avatar
Default 2007 Pacifica 4.0 crank no start issue
I have a 2007 Pacifica 4.0 that will crank and not start. It had a p0340 code and I replaced the cam and crank sensors. I also replaced the computer as well.
The 3 grounds on the body looked bad and one connector just broke apart so I cleaned and replaced the connector. I also replaced 2 wires going to the cam sensor to the PCM.
I also grounded the ground from the cam sensor harness to the body to see if it needed a stronger ground. (Not sure if that can cause an issue at the PCM).
I’m trying to check spark but that’s hard since the coil over packs are under the intake.
I can hear the fuel pump spinning.
Not sure how to check the timing belt short of removing the cover.
On a side note the car used to stall when backing up when the weather was cold.
Any guidance would be greatly appreciated!
darkstarEuro
Apr 9, 2017 07:11 AM
BigBlocksnHardrock
Nov 26, 2016 05:57 PM
Nealsllvn
Dec 24, 2015 08:28 AM
Turboblackbird
Aug 29, 2015 07:49 PM
BigBlocksnHardrock
Apr 7, 2007 12:19 PM
