2007 Pacifica 4.0 stalls when put in gear when cold
Old Oct 20, 2019 | 02:00 PM
Cgrose87's Avatar
Default 2007 Pacifica 4.0 stalls when put in gear when cold
2007 Pacifica 4.0 will stall when its cold and put into drive or reverse. If let warm up for 30 + minutes, it will run. Sits over night and will do it again. Scoured internet with no fixes. Replaced egr, seemed to fix for a few days but back to stalling. New alternator. New battery. Only thoughts left is MAF, or something with transmission. Any help or ideas much appreciated, I'm stumped.
Old Oct 20, 2019 | 03:26 PM
REBEL59's Avatar
NO CEL??? IF the motor still uses a throttle cable, clean and or replace the idle air control valve. IF it has the electronic throttle, clean the throttle body/butterfly area.
Old Oct 20, 2019 | 03:50 PM
Cgrose87's Avatar
Only one cel which is small evap leak. Narrowed down to cracked fitting in fuel pump, had for a while. I've cleaned the throttle body 3 times, no change each time. Maybe MAF? Not sure a bad MAF would cause this though. The only other lead I could find was a torque converter solenoid gone bad but was a different but similar issue.
Old Oct 20, 2019 | 06:33 PM
REBEL59's Avatar
I'm not up on the 4.0...BUT I've never known a mopar to use a MAF sensor, a MAP sensor YES! but that should throw a code.What is the idle RPM COLD? should be around 1,000 rpm and in gear drop to about 750. Almost sounds to me like a major vacuum leak when the motor "rocks" being put into gear(like a bad motor mount) and a breaking major vacuum hose.
Old Oct 20, 2019 | 07:45 PM
Cgrose87's Avatar
1000 idle, a quick hard shudder then stall. Idles just fine, revs just fine before shifting. I agree on the code, but the one it has is the small evap leak. Like I said I know there's one by the fuel pump but very small. Never affected running and staying cold the year prior. I know some people have mentioned no code and a bad MAF... or MAP.
money pit 69
Nov 29, 2019 02:01 PM
Cgrose
Feb 12, 2019 07:06 PM
dedwardk
Jan 4, 2013 08:21 PM
bakerman6578
Aug 17, 2012 09:12 PM
vince01
Nov 3, 2007 09:52 PM
