Engine Oil Pressure Switch
Hi there, i’ve read your post “My oil light comes on a couple of seconds after the engine is started every time. I can turn it off and restart the engine and it goes away. Always comes on the first start no matter if engine is cold or just driven a 100 miles. Shut down and restart and no light issues. Anyone run across this problem before? Any help and info would be greatly appreciated as i am stumped on this one.
“. I have the same problem and i cannot fix it. I have changed the sensor and the light comes again. Can you tell me how you fix it?
thank you
“. I have the same problem and i cannot fix it. I have changed the sensor and the light comes again. Can you tell me how you fix it?thank you
its not an issue think about it. when you have not started the car say 8 hours over night. most of the oil is in the oil pan so starting up the engine it has to be picked up from the pick up screen through the oil pump through the filter passing the pressure switch up to the top of the engine and so on.
When you shut it off and restart it what has already happened?
thank you
1) Remove the oil pressure switch.
2) Install oil pressure test gauge, Special Tool C-3292 with Adapter 8406.
CAUTION: If oil pressure is 0 at idle, Do Not Run engine at 3000 RPM.
3) Warm engine to normal operating temperature.
4) Monitor gauge readings at idle and 3000 rpm .
OIL PRESSURE
NOTE: At Normal Operating Temperatures
Pressure @ Curb Idle Speed 34.47 kPa Min. (5 PSI MIN.)
Pressure @ 3000 RPM 300 - 724 kPa (45 - 105 PSI.)
CAUTION: If pressure is zero at curb idle, DO NOT run engine at 3000 RPM
There might be something in the wiring if the sensor was already replaced. Both of mine show no signs of low pressure I have only used synthetic oil and filters. from new and it gets changed very often. I have no sludge, the engines run like new. Check the pressures if low it could be the oil pump or bearings
Check oil pressure using a gauge at oil pressure switch (Fig. 125) location.
OIL PRESSURE
OIL PRESSURE
Have a 2007 Limited w same problem. Used to only happen when temp was below 50-6- degrees , and only on initial startup. Now, every time even though it's summer. What do u mean changed AC connector w oil pressure connector?
Regarding basically all the failure modes listed in this thread... yep, that's what this switch does. The exact same switch is used across many Chrysler engines.
Eventually it'll fail internally and go from weeping to leaking to puking oil out. that's when I finally changed it in my Stratus. Pulling the passenger axle made that job easier.
