I知 at a loss
Old 02-07-2024, 04:26 AM
NateDog2002's Avatar
Default I知 at a loss
So I have been fighting with this 07 Pacifica and can稚 seem to fix the right thing. I have replaced a lot of stuff starting with the coils nd spark plugs, alternator then the o2 sensors. I have checked my fluid levels and all are at proper levels.
After I have done this work the problem goes away for a few hours (it shifts properly) but if I park and turn the car off the problem comes back. Last night after I got done working on it I went to start it nd a whole bunch of smoke comes from the exhaust. So now I have a blown head gasket I知 gonna say!!!! I put some k seal in and everything. I noticed a lot less smoke then before after I finished with that I drove it without a problem till I got back home. I had to run down the road and the same sluggish, not shifting to right gear. I don稚 know what to do or what it is plzzzzz HELPPPPPP
Old 02-07-2024, 03:07 PM
well smoke from the tail pipe and transmission shifter issues are two completely separate issues. you need a scanner that can get into the transmission computer and see what the codes are before anything is done.
Old 02-07-2024, 09:55 PM
ggoose's Avatar
What color is the smoke, white points to coolant, blue points to oil, black points to gas/fuel?
snake7247
04-28-2014 11:14 PM
deanncaz
12
02-28-2013 11:11 AM
CherieLW
10-11-2012 02:28 PM
arcam2004
11-25-2011 01:58 PM
Nick Owen
9
05-08-2010 08:51 AM
Quick Reply: I知 at a loss
