2004 Pt Cruiser stalling issues.
Old May 11, 2023 | 07:53 PM
sota's Avatar
why are you ordering a PCM?
before spending another dime, why not spend some time TESTING the wiring to make sure it's intact?
Old May 12, 2023 | 12:28 PM
TeyM's Avatar
could you tell me where you would start? Thank you
Old May 12, 2023 | 09:45 PM
sota's Avatar
get a copy of the service manual.
start mapping out the wires from the ECU to the O2 sensors.
with both of them showing "high", I'd start tracing from the ground point back to the sensor.
I'd also check C102 and make sure it's connected.
Old May 14, 2023 | 11:14 PM
TeyM's Avatar
Hi there all. I did trace the wires. However I do have a question. When I took the old cat off. There was a ground wire connected to it that had rusted off. Yet there was part of a braded ground on it. It was not attached do to the fact that it had rusted. I plan on replacing that and putting a clamp on it to secure it to the exhaust pipe... Any thoughts?
Old May 22, 2023 | 05:34 PM
  #15
CarlosHRNYC's Avatar
I was going to ask if you cleaned all the grounds? There are two in the engine bay on the drivers side wall by the airbox (one 13mm, one 15mm), one on the back of the starter (15mm), two on the passenger side (one by the top engine mount (I think that's a 10mm) that goes to behind the engine (13mm long bolt)), one on the passenger side wall behind the A/C lines. Give all the connections a good cleaning with scotchbrite pad or high grit sandpaper. You want the connections to be nice and shiny. Take a wire brush and clean all the bolts you just took out. For the connections bolted to the walls, sand the contact points to bare metal so they have a clean contact.
Since you pretty much changed everything possible, it wouldn't hurt to make sure your electric maintains a complete circuit at all times.
Good luck
Old Jun 7, 2023 | 11:18 PM
  #16
TeyM's Avatar
Update, I want to thank all you guys for helping me out. I threw a lot of money in this PT Cruiser. The problem was the PCM. The car drive fine. It probaly the best its driven in 10 plus years.
JPVortex
Sep 15, 2021 01:42 PM
John_P
Dec 21, 2019 09:29 PM
samy
Nov 11, 2018 04:19 AM
limeyjoe
Jun 12, 2009 12:38 PM
SatiAh
Jun 8, 2009 10:10 PM
