Idles erratically
Old Aug 18, 2021 | 02:28 PM
GARYH's Avatar
Default Idles erratically
The car had a few symptoms.
- Stalls if not pressing the gas pedal while parked
- When after cleaning the throttle body, it stays running now, no longer stalls, but idles strangely idling higher than normal then lowering to normal. Even when the throttle body is closed, idles high
I replaced the IAC valve (Idle air controller valve) but no help. Air cleaner is clean. But i do hear what sounds like a massive air leak in the plenum air inlet manifold behind near the throttle body. Is this normal? Could a leak (crack) cause this idle issue?
Old Aug 18, 2021 | 07:09 PM
ggoose's Avatar
Year and mileage please
I suspect you have a vacuum leak. One item to check is the vacuum line to the master brake cylinder. It will disconnect relatively easily. Other than that there are other lines coming off of the throttle body and intake plenum that may have been dislodged. You should also check the pcv hose as it may have split. You should not be hearing an air leak
Old Aug 22, 2021 | 04:37 PM
GARYH's Avatar
Default Erratic idle
2001 PT Cruiser Limited Edition
Old Aug 23, 2021 | 02:56 PM
Take a piece of tubing 2-3' long. Hold one end close to your ear and poke around near all the vacuum hoses and fittings with the other end. If you hear a hissing noise near something, there's the leak. Good luck.
Old Sep 8, 2021 | 06:43 PM
GARYH's Avatar
I found this image on EBAY of what the back of my engine looks like. I found a massive leak in what is perhaps a seal or gasket that is possibly mounted in this fitting juncture. (See image)
While the engine is running, you can hear the massive leak and place your fingers back behind the engine at this connection and feel the leak. Could this be causing my erratic idle control?
Old Sep 8, 2021 | 09:02 PM
ggoose's Avatar
Yes, there is a blue seal/gasket behind the plate called the egr tube seal. The bolt sizes are 8mm and 13mm. The difficult part is pulling the tube far enough out to replace the seal, at least 1/2 inch.
Yes, if it a massive air leak as you describe it will cause an erratic idle. You may have located the problem. As a note it is necessary to remove the plate when replacing the spark plugs as the intake plenum needs to be moved out of the way to get to the plugs.
Old Sep 14, 2021 | 02:21 PM
GARYH's Avatar
Thank you ggoose!!
Old Oct 18, 2021 | 12:32 PM
GARYH's Avatar
Installing the new seal at this fitting fixed the idle problem as you suspected. Thanks for your insight!!
shelbygt88
Feb 11, 2021 09:57 PM
money pit 69
Nov 29, 2019 02:01 PM
m_tobin
May 10, 2011 07:30 PM
bbyers
Feb 21, 2010 09:29 AM
vince01
Nov 3, 2007 09:52 PM
