FRONT BRAKE PROBLEMS - VOYAGER 2.5 CRD Year 2006
Old Apr 7, 2016 | 07:44 AM
Dea-ita's Avatar
Default FRONT BRAKE PROBLEMS - VOYAGER 2.5 CRD Year 2006
Hello, I need help with a problem with my front brakes.
About one year ago, whilst driving in normal city traffic conditions, after braking a few times the left front brake progressively started to remain slightly engaged causing the disc and pads to overheat. As the car had been stationary for a long time, my mechanic decided to change the front left hydraulic tube, after this the car apparently went well for some time.
Recently, the problem presented itself again whilst driving on a mountain road but without in anyway driving the car hard. This time it happened to both front brakes. the impression was that the clamps that hold the pads do not open again completely when I release the brake pedal, which looses play engaging immediately.
This time the mechanic changes the discs (because they had warped), the pads and reconditioned the clamps (with kit code 0506 6379 AA) of course also changing the hydraulic brake oil and again the problems went away.
Last week again whilst driving absolutely calmly on a mountain road it happened again. we cooled the wheels with water and the problem stopped, allowing me to do 400k of motorway without problem, and also now there would seem to be no anomalies.
My mechanic does not know what to do at this stage also because he has been unable to witness the problem directly and he is afraid of making me spend money for solutions that don't work
Has anyone had the same problem and, if so, what's the solution!
Many thanks and greetings from sunny Rome!
Gianluca
Old Apr 7, 2016 | 08:10 AM
matgriff's Avatar
Quite a common problem on the Voyager CRD.
It's the brake calipers. The pistons are made of a kind of ceramic material (at least they were on my 2001)
When you push the pistons back into the calipers, eg when you fit new pads, then they tend to stick on the rubber seals, which makes the brakes drag.
You can get re-build kits with new steel pistons, this cures the problems.
Generally it's intermittent, hapens some days and not others. Just Google it there's plenty of info about it.
Mat
Old Apr 7, 2016 | 12:52 PM
And rebuilt the pistons/seals in the calipers with red brake grease and that will give the pistons better lubrication. New dust covers of course.
Attached Thumbnails FRONT BRAKE PROBLEMS - VOYAGER 2.5 CRD Year 2006-chrysler-abs-red-grease.png
Old Apr 7, 2016 | 01:03 PM
matgriff's Avatar
The kits I used came complete with pistons, seals & red grease :-)
Old Apr 7, 2016 | 03:19 PM
Where from and are they good quality Matgriff.
Old Apr 7, 2016 | 06:44 PM
Dea-ita's Avatar
Thanks everyone! Mat got the point! Mario (the mechanic) told me about the piston of a "strange" material...
Where to buy a good quality rebuild kit with steel piston.
Thanks again!
Old Apr 8, 2016 | 01:36 AM
matgriff's Avatar
I just got them off Ebay, they were made by Budweg
Worked absolutely fine :-)
Mat
Old Apr 11, 2016 | 04:20 PM
Dea-ita's Avatar
FYI below correspondence on this matter from Budweg.
Niels Nørregaard
Tel.:+45 63 14 33 20
Email: nin@budweg.com
http://www.budweg.com
Hallo
From your informations we think that you need repair set and piston for 343266/67 (left/right) caliper.
Repairset = 206601
Piston = 236601
You can check these on our website. All depend on how old your car is and engine size.
We have no partners in Italy so where you want to buy from I can not tell.
We have partners in France, Austria, Spain or Kroatia – these must be closest to you.
You can not buy direct from us.
Old Jul 11, 2017 | 01:03 PM
Dea-ita's Avatar
Hi ! I wish to give feedback after 1 year...
I have installed the budweg caliper piston and service kit which I bought from https://brakeparts.co.uk
Caliper piston
https://brakeparts.co.uk/part/BCP6601
Caliper service kit:
https://brakeparts.co.uk/part/BCK6601
I have tested the brakes for 15000 km sometimes even in heavy conditions (mountain roads with trailer with 3 motorcycles on it) and it is working very well!
Thanks to the Forum!
kev.williams
Sep 30, 2014 10:39 AM
Vmaxxer
Jun 18, 2014 02:03 PM
jassypop
Mar 1, 2013 05:52 AM
il_capo_dei_cattivi
Dec 21, 2010 11:21 PM
atlantisx
Oct 29, 2007 10:04 PM
